Which Clutch for a Turbo Accord?
Old Nov 11, 2002 | 12:55 PM
Howitt's Avatar
Default Which Clutch for a Turbo Accord?
I will be turboing my accord in the next month and my stock clutch is not going to last since its already slipping. My 2 choices right now are a Action Stage 2 kevlar or Metal. Which would you choose and why?I am leaning toward the kevlar My Turbo setup is a junkyard one running a smc/btm anywhere from 7-13 psi. In the future I plan on building another engine and using hondata and want to plan for the future. Thanks for the input.
[Modified by Howitt, 9:59 PM 11/11/2002]
Old Nov 11, 2002 | 12:57 PM
2000Accord5sp's Avatar
Default Re: Which Clutch for a Turbo Accord? (Howitt)
ACT. That's what I went with. It'll definately hold it...how much hp do you intend to push?
Old Nov 11, 2002 | 12:59 PM
Howitt's Avatar
Default Re: Which Clutch for a Turbo Accord? (2000Accord5sp)
on the junkyard setup I am hoping to push around 230-250 while with a built engine I hope to aim for 350-400
Old Nov 11, 2002 | 01:37 PM
CD8's Avatar
CD8
act 6 puck. kit # HC1-HDR6
Old Nov 11, 2002 | 05:31 PM
MSaccordNR's Avatar
Default Re: Which Clutch for a Turbo Accord? (exaccord)
I use Centerforce Dual Friction
Old Nov 12, 2002 | 10:01 AM
RotaryBzzz's Avatar
I would read up on clutch compound materials first. Especially on that built motor....are you using an aftermarket lightened ($$) flywheel? Some compounds will chew up the flywheel; other compounds are much-much better at preserving surface life/integrity. It would be nice not to destroy your fancy-pants flywheel.
One idea that I've come across is having a less aggressive compound facing the flywheel, and a more agressive compound on the pressure plate side. Since you replace the pressureplate side anyway. Hybrid dual compounded clutch disc = cool. Talk to a clutch remanufacturing shop and they should be able to custom make one. Unless its a new OEM Daikan or Exedy set ...clutch "namebrands" are very meaningless to me. Btw, clutchmaster is all remanufactured stuff.
Old Nov 12, 2002 | 10:25 AM
Razor's Avatar
Default Re: Which Clutch for a Turbo Accord? (RotaryBzzz)
exedy
Old Nov 12, 2002 | 10:18 PM
Lowness's Avatar
ACT
Old Nov 13, 2002 | 12:52 PM
accordfreak's Avatar
Default Re: Which Clutch for a Turbo Accord? (lowness)
i'm getting clutchmaster stage 4 w/ CM flywheel
galgajo
Apr 25, 2009 06:10 AM
IgnitionZ055
Nov 4, 2008 06:06 AM
fknslmd
Jan 28, 2004 08:58 PM
JDM CTR EK
Aug 6, 2003 08:25 AM
Howitt
Nov 11, 2002 01:50 PM
