Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
SRS 3-4 code
Old Sep 19, 2017 | 07:15 PM
Maark's Avatar
Default SRS 3-4 code
Hello, I have a problem of SRS with my Civic 2007. I reset my airbag code and I have code 3-4. I check the belt tensioner and the resistance is 2 ohm. I compared it with the passenger belt and it is the same. Could the problem come from wiring or have I done my tests wrong?
Old Sep 20, 2017 | 05:20 AM
nsxmatt's Avatar
Default Re: SRS 3-4 code
Did you have an airbag deploy? Did you change the SRS control unit?
Old Sep 20, 2017 | 08:10 AM
Maark's Avatar
No I didn't have an accident. I happen to see a professional and the problem is the right curtain airbag. My vehicle is at the end of is life so I have 2 choices, replace the cushion or install a 2 ohm resistance for the bypass. Someone has already bypassed a lateral cushion?
luissolis1
Honda Civic (2001 - 2005)
Mar 17, 2014 05:28 AM
GSE980
Jun 4, 2006 01:15 AM
