Why did my radiator crack? Bad mechanic?
Took my car to the mechanic for head gasket repair. He fixed the head gasket kit, changed oil, went to the machine shop, and a [block plane]? Less than a week later my radiator cracked! I don't believe this is just a coincidence. I think he did something wrong and just didn't change a part that was needed.
Not likely the mechanics fault. When your car is getting too hot, pressure increases in the cooling system. That combined with the age and thousands of heat cycles would probably been the cause.
I took it to this other mechanic an he tested the head gasket by doing the coolant test. He started the cool with the radiator fool, and coolant exploded out like a volcanic eruption. That's worst than it was before I took it to the mechanic.
That looks like old age failure to me. Trust me, I'd be the first to jump on a shitty mechanic, but from the look of the crack it appears to be from just normal old age/usage.
What is the timeline we are looking at here? Mechanic replaced head gasket, then (immediately/the next day/2 months later?) you noticed the radiator leak? Or did he replace it, then (immediately/the next day/2 months later?) it started shooting coolant out the radiator cap area?
It is possible that the crack in the radiator caused you to lose coolant and overheat, warping the head and blowing the head gasket. Then you got the gasket replaced, leaked coolant again from the crack in the radiator, and overheated again.
Regardless, the radiator needs to be replaced. Then you can troubleshoot from there.
Kadams587
Aug 16, 2018 04:04 PM
xTomei
14
Jun 23, 2010 02:50 PM
hondaStarter
24
Sep 10, 2008 12:50 PM
sparck1
Jun 25, 2004 12:46 PM
