swap MT transmission into AT transmission
Old Sep 19, 2017 | 07:43 AM
vohungdung's Avatar
Default swap MT transmission into AT transmission
Dear everybody!
i am honda acord 1995 owner
Can i swap the transmission of AT engine to MT transmission fit or not? it mean t2w4 can fit to f22b1 or not?
Thanks Pro
Old Sep 19, 2017 | 08:07 PM
GhostAccord's Avatar
Default Re: Ask about MT & AT transmission
Yes!
Without knowing what engine you have in your car, as they had different engine and transmission combinations in different countries, I'm going to say yes. As Honda made most of the Accord AT & MT transmissions are interchangeable between 90-02 USDM. Not 100% about Vietnam.
Old Sep 21, 2017 | 09:45 PM
vohungdung's Avatar
Originally Posted by GhostAccord
Yes!
This car is US car, not Vietnam car. my engine is F22B1. the transmission on h22 engine. is it fit to my engine?
Old Sep 21, 2017 | 10:19 PM
holmesnmanny's Avatar
yes, no problem, you just change the driver side mount to the prelude mount and bracket and it will be plug and play
also, use the 97-01 prelude power steering bracket to keep power steering
Old Sep 22, 2017 | 07:34 AM
Default Re: swap MT transmission into AT transmission
And your ECU/TCU (transmission control unit) will probably throw a few codes after you remove the automatic transmission. If you can find a 1994-1995 ECU/TCU for a 5spd F22B1 Accord that would work as well.
Old Sep 24, 2017 | 12:59 AM
my bad, I thought you were swapping in an h22a engine as well...the tranny will likely have the studs in a different slot, you will need to either move the studs over on the t2w4 or have to drill holes to accommodate the studs. you also might need to extend the speed sensor wiring for the new tranny, but it will mount and run just fine
like Ghost said, you just need the 94 or 95 year f22b1 MT ecu after doing the AT to MT swap
muchakuya
Jun 28, 2018 09:05 AM
Pprinceazabu1
Sep 14, 2017 02:42 PM
kravcenko
Feb 10, 2016 12:34 AM
rockenuptown
Jun 9, 2007 05:52 AM
