Fuel line flares and fittings
Old Sep 18, 2017 | 04:57 AM
r_kage's Avatar
Icon5 Fuel line flares and fittings
I seriously need some guidance for repairing/replacing fuel lines for my 1995 Accord EX, 4-cyl.
The picture on the parts ordering page isn't clear, and I really got the impression by people replacing (repairing??) fuel lines that I just needed to double flare them like the brake lines. I thought the fittings would be the same, just a different size. BUT when I saw an aftermarket fuel line kit on Ebay (for a 2000 Accord), the line ends are not flared in the same way--some are squeezed, one has an o-ring slot. I'm not sure if that's also true of my car. The reality is, the lines look so bad I'm afraid if I move them, they'll fall apart. Maybe it looks worse than it is. (So when people say they double flare, is this just based on cutting out a segment and putting a new segment into an existing line?)
So what I want to know, by anyone with any experience replacing them, is what fittings, and what tools I need to do this job--special fuel line flaring tool?? Or will a regular one work. I ordered Ni-copp in 5/16 and 3/8. If I can do this today, I want to---otherwise I have to cancel my inspection appointment and I really need my car.
I took my car for pre-inspection and nothing was mentioned about the fuel lines. When they said my brake lines are leaking, I directly asked about the fuel lines, and they said the fuel lines are not leaking so I really considered doing fuel lines as being optional, but just a good idea--and now it looks like I have to.
(I know I put an inquiry about this in my thread about brake lines/fuel lines--when I thought fuel lines were optional--but I wanted to draw attention to the fact that I really need help regarding the fuel lines right now. Sorry!)
Old Sep 18, 2017 | 05:07 AM
r_kage's Avatar
Default Re: Fuel line flares and fittings
The flares don't look like bubble or double flare, but kind of like a mushroom (in image of aftermarket lines for 2000 Accord). Not sure if I need push connect "flares" or if even you can use threaded adapters (with the right fitting end), then do a double flare?
Any info is more than appreciated! I literally stopped what I was doing yesterday when I saw the lines and am feeling pretty defeated....
Old Sep 18, 2017 | 08:36 AM
r_kage's Avatar
Mastercool Hydraulic Universal Flaring 71475--does it all?? Anyone use it for fuel lines??
Amazon Amazon
Thank you!!
Old Sep 18, 2017 | 12:15 PM
r_kage's Avatar
And... I tore up the supply line trying to loosen the frozen nut with vise grips...
I saw some videos of people installing nylon line--it looks a lot easier than messing around with flaring fuel line.... I'd be interesting in knowing the pros and cons.
Old Sep 19, 2017 | 06:17 AM
r_kage's Avatar
I also can't get the bolts holding the fuel tank straps on loosened. One of them doesn't even have enough clearance to put a socket on it. Any tips?
95accordian
Jul 19, 2016 08:35 AM
danteisme
May 27, 2015 07:35 AM
SOHCMAN
May 15, 2012 05:29 AM
Nick M
Jan 30, 2006 12:02 PM
justinCO
Jun 7, 2002 08:55 PM
