90 DX B18A to B20 question
Old Sep 17, 2017 | 02:55 PM
ratchetEDsedan's Avatar
Default 90 DX B18A to B20 question
So I have a 90 DX sedan, already swapped with a B18a running OBD0, and it snapped a rod. I was thinking of getting a B20, there's a wealth of them that are OBD2, and they're cheaper, so I just want to make sure I'm not overlooking anything considering the swap.
I need to OBD1 swap the car and the engine. My checklist is:
1. Jumper harness for the ECU
2. Splicing OBD1 injector plugs into the harness
3. OBD1 dizzy and either splicing plugs or getting a jumper.
​​​​​​​4. Four wire 02 stuff. Rywire harness comes with provisions for it.
I didn't see any sensors with different plugs between OBDs. Is there a knock sensor or something else on the B20 that my current engine lacks? Can I just delete it or should I find an OBD1 pinout and wire it up? Thanks in advance
Old Sep 17, 2017 | 06:30 PM
Marcos Barrios's Avatar
Default Re: 90 DX B18A to B20 question
you know a b20 is just like a b18 only a little bigger
you can drop the b20 into your car and not have to modify anything if you were already running a b18
you would only have to change the motor and keep everything else
your wiring your intake mani your header you can keep all your old stuff
it all bolts up because the b20 is the same as the b18 other than the fact that its a bigger motor
Old Sep 17, 2017 | 06:45 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Yep, it's plug and play. Keep all your old stuff, swap it to the b20.
You just have to move the temp sensor wiring from the hard water pipe to the thermostat housing. Swap the old crank pulley to the b20.
Old Sep 18, 2017 | 04:27 AM
So I checked out a thread for OBD0-1 swap on an Integra and basically it's just what I had listed, along with the resistor box delete for OBD1 injectors.
​​​​​​​If I used all my B18 gear that process would be fine, so that temp sensor is the only thing different? No knock sensors or anything I need to know about?
Old Sep 18, 2017 | 04:29 AM
And out of curiosity Cao why would I swap the crank pulley? Are the accessory drives different?
efbastard
Feb 13, 2017 07:11 PM
haroldthefly91crx
Apr 21, 2008 04:50 PM
silver-16v
Apr 8, 2008 06:13 AM
silver-16v
Apr 7, 2008 06:44 PM
1SIKCRX
Mar 27, 2004 04:43 PM
