Suddenly lost compression after driving a week with a swapped z6/y7 mini me
Old Sep 16, 2017 | 12:50 PM
Chris Barbrow's Avatar
Default Suddenly lost compression after driving a week with a swapped z6/y7 mini me
Ok so i did a mini me swap in a 98 civic lx, auto. After getting the motor in i drove the car for about a week and it suddenly lost compression in 2 & 3, 4 had about 80psi and 1 had about 135-140psi. Needless to say after reading so many options of what the problem could be i pulled the head to do a thorough inspection of cam, valves & pistons. Theres no indication on piston heads or bottom of valves that contact has been made to bend them, and my seals on my pistons arent leaking so i know its not thru the block and no air is coming thru the radiator, and the head gasket is fine. Ive checked timing and adjusted the cam 1 tooth at a time for about 2 days. Set my cam at 1 tdc & crank at 1 tdc w dizzy set to spark on 1 and still have no compression. Doin a leak down test at each piston it seems like my exhaust valves arent closing all the way and letting the air escape. Could my valve seals be that screwed or am i jus totally missing somethin? And yes dizzy works fine, got spark on all 4 plugs, and timing seems to be adjusted right. And not sure if they are all valves are suppose to close after cam & rocker arms have been removed, but all intake valves are closed and all exhaust valvles are slightly open
Old Sep 17, 2017 | 06:34 AM
mk378's Avatar
Default Re: Suddenly lost compression after driving a week with a swapped z6/y7 mini me
The valve springs need to pull the valves completely closed when nothing is pressing on the top of the stem. That is really bizarre, perhaps someone put the head together with the wrong parts.
Old Sep 17, 2017 | 06:16 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Can you post a picture of the valve stems, keepers and top retainers? And is any of the cylinders TDC in the picture you posted?
Old Sep 17, 2017 | 08:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Regardless of whether a camshaft is installed in the cylinder head pictured above or not... there is no point in the cam rotation where ALL eight exhaust valves are open. Something is significantly wrong here. My first thought would be an improper valve adjustment... but this looks way too tight, and it would be unlikely that it ever would have run at all. Loosen the tappets all the way and see if the valves close completely. If not, the valves may be the wrong ones for the head, or something is bad wrong with the valve seats... which incidentally, appear to be missing. How about a close-up pick of one chamber at a slight angle to show the gap between the exhaust valve and valve seat.
Old Sep 18, 2017 | 11:01 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I was thinking, bent or trashed retainers. Much like improper fitted titanium retainers that drop valves... Then again, it's not likely to happen to all 8..... Good point.
Old Sep 18, 2017 | 06:30 PM
Thanks for to input guys. Ill defiantly be pullin the springs off tomorrow and take some pics of everything and repost as well as that close up. Had a feeling something was very wrong considering it was supposedly rebuilt by the who sold it to me and claimed he cleaned and polished the valves and took the intake & header off to discover none of them have been touched so i can only wonder what else could be wrong.
B_Swapped93
Aug 2, 2015 12:05 PM
osgn
Mar 1, 2009 01:31 AM
CO_CReX
32
Jun 17, 2006 07:43 AM
nikolass
Apr 18, 2006 06:57 PM
not so civic
Jul 20, 2003 06:40 PM
