-Clean Title
-Viper alarm systen $300
-LoJack anti theft equipped $700 (If car is stolen, you call LoJack and 911 and give them the car info such as license plate and vin# and police will recover the vehicle via the LoJack GPS anti theft system!
-Smogged August 31, 2017 (good for 90 days) (you need a smog when registering a vehicle at DMV)
-Registration good until November 2017
-NO accidents
-Clean CARFAX
-Original Acura Dealer window sticker and owner's manual in hand.
-Elderly owned, never abused or modified.
-California car since 2006, Oregon before then, NO RUST.
-COLD Air conditioning, hot heater
-Everything functions.
-NO CHECK ENGINE LIGHT
-NO LEAKS
-214,000 miles running STRONG (test drive to see what I mean)
-Citrus Silver Metallic Original paint
-Sliding Moonroof, dual airbags, anti lock braking aystem, 4 wheel disc brakes.
-Automatic 4 speed transmission, NO SLIPS, perfect shifting condition.
-All Original gray factory leather interior(driver seat has rips, normal wear and tear)
-140 horsepower Dual over head cam, 1.8 liter 4cylinder gas saving (32mpg highway 28mpg city) economical engine.
-100% original besides stereo (has USB and AUX input)
-4door with nice spacious trunk.
-Oil pan gasket replaced $26
-10w30 oil change with Castrol Edge & oil filter. Oil changed religiously every 4000 miles or every 3 months.
-New OEM Replacement Radiator & fan and radiator cap and fresh 50/50 antifreeze $150
-New NGK Sparkplugs $23
-New sparkplug wires $35
-New Fuel Filter $18
-New front and rear brake rotors and pads $150
-New catalytic converter $250
-New Primary o2 sensor $48
-New serpentine belt, timing belt, tensioner and water pump as well as antifreeze $850
-New Acura Automatic Transmission Fluid $37
-New Cam Seal , New valve cover gasket $32
-New complete Distributor assembly $150
-Yokohama tires with 40% life.
*Car is not perfect, it is a 19 year old car and is original paint. Straight body, clear coat is gone on roof, also hood, trunk & spoiler could use a wetsand. (Clear coat peeling on the hood, spoiler, trunk and rear upper quarter panels)
Car is dependable as can be and is ready for a new owner, I've seen these b18b1 engines taken care of with well over 400,000 miles multiple times.
No trades, sorry.
$2900 or best reasonable offer.
The car is located in Port Hueneme, CA next to the CBC Naval Base.
