rear sway bar 99ek
to install a rear sway bar on a 99 ek, all i need is the 2000 si rear sway bar parts? nothing else correct not try to install rear lca or sub frames trying to keep the stock look as close as possible.
For an si sway bar just the bar and endlinks, if you run a bigger swaybar (like a type r) it's suggested u run some kind of a subframe reinforcement brace.
ekinshuya
May 31, 2009 07:36 AM
Tuner Eddy
Dec 28, 2007 04:59 PM
Jchild420
May 20, 2004 08:55 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
