Removing AC and PS
Old Sep 14, 2017 | 11:37 AM
hochroter's Avatar
Default Removing AC and PS
Just picked up a cheap 1995 civic coupe was gonna try my hand at a drag car/weekend warrior. Need some guidance on removing these two components.
Old Sep 14, 2017 | 11:41 AM
Chance EG's Avatar
Default Re: Removing AC and PS
Devsport PS Loop for the PS delete, AC you just need to have the freon vacuumed out at a shop, then pull off the compressor, belt, condenser, all the lines, evap, dryer, etc...
Pretty straightforward... Also heads up that people around here will eat you alive if you ask questions like this which have been covered 100x before, use the search function or try Google.
Old Sep 14, 2017 | 11:55 AM
hochroter's Avatar
Thanks for your input, why would they do that? most of the threads are 10 years old with no pictures or any real information besides the questions why are you removing it? are you sure? it sucks with no PS or ac bro why? blah blah
Old Sep 14, 2017 | 04:08 PM
the171's Avatar
A proper manual rack is the best idea if no PS is a must. Looping the lines on a hydraulic rack makes the steering real heavy. At least at slow speed but even at high speed it kinda sucks. As for the AC... Just grab a ratchet and unbolt it. Assuming the system is discharged.
Old Sep 15, 2017 | 05:25 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Rather than loop the line you can put a breather on the line ports on the rack, and the steering won't feel nearly as heavy.
nomoreavril
Apr 7, 2009 11:10 AM
IP RACING
Mar 13, 2009 09:16 AM
Burgess0909
Jun 30, 2007 12:08 PM
erikiksaz1
Sep 24, 2004 07:50 PM
nY's FiNeSt
31
Apr 22, 2003 09:26 AM
