Rear Camber Adjustment
Old Sep 13, 2017 | 03:14 PM
CosmicJ's Avatar
Default Rear Camber Adjustment
I have had an alignment done at a Napa service center. I went to the Honda dealer for other stuff. They said the alignment was off and they adjusted the bolts on the rear camber. I went back to Napa and they said you cannot adjust the rear camber without a kit. By the way the machines are Hunter Hawkeyes both relatively new and both adjustments are not close at all.
Old Sep 13, 2017 | 04:26 PM
GhostAccord's Avatar
Default Re: Rear Camber Adjustment
Depending on what year your accord is, always nice to let people know what chassis you are referring to.
There are usually lower A arm adjustment bolts in the rear. They are the bolts located on the cross member end of the lower A arms. They are used for camber adjustment on the 90-97 Accords I know of for sure.
This is why it is best to take your car somewhere that knows about your vehicle.
Old Sep 13, 2017 | 04:34 PM
And I just checked the parts catalog for the 6th gen 98-02 Accord and they also have adjustment bolts on the rear lower A arms.
Old Sep 14, 2017 | 04:38 AM
Fitz Williams's Avatar
10 Year Member
I have always understood that the adjustment on the lower rear suspension of the Gen 5 Accords was for toe-in only, and there was no camber adjustment. Camber adjustment can be done with an adjustable upper arm, or by using shims under the mounting point of the upper arm. Of course the shims will only give you more positive camber, so if you want to increase negative camber, you will need a kit.
Old Sep 14, 2017 | 11:59 AM
Oh ****... yes you are 100% correct, they are for toe adjustment. That's why nobody brings their cars to me for an alignment...lol
If I had of looked at page 18-7 in my shop manual I would have seen that plane as day!
drsab2000
12
Oct 31, 2013 09:39 AM
Blacksole
Honda S2000
Nov 9, 2011 06:58 AM
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
Kid1320
23
Feb 12, 2003 10:01 PM
