Radiator & AC fans do not kick on. Not sure what to test next!
My OLD fan wasn't working -- bridged power to it and was not working so I replaced it.
NEW fan was not working -- bridged power to it and it would work.
A: My radiator fan (and AC fan) won't kick-on unless...
Any further tests I can perform? I'm at a loss.
Edit: When I replaced the Radiator Fan, I did have to do a partial coolant flush (drain ~1/2 to remove upper radiator hose & refill after).
Edit 2
- ...I bridged power to the fan directly (both fans function).
- ...I bypassed the relays (both circuits function).
- ...I detached the temperature-sensor connector and bridged the circuit and turned the key to [ON] (both fans activate).
- I have not had any overheating issue at all.
- The A/C is no colder then the fan set to "cool". *This is what prompted me to test the fans in the first place.
- The A/C does not activate any fans.
- I can activate the A/C clutch manually at the relay.
- A few times, after driving awhile, I have checked to see if the fans would run at idle. So far I have not seen the fans run without myself bypassing something to force it on.
- The ODB Torque App shows a coolant temperature of 88 to 96 degrees Fahrenheit after some 5 minutes of driving. Same thing while driving on the highway.
- I've noticed that the temperature gauge (on my dash) will not settle at 50% but slightly less (around 35-40%). While warming, the dial does slowly raise as you'd expect until around 35-40%. I know it was half way less than two months ago.
Edit 2
- Just checked the voltage going to the ECT (Engine Coolent Tempeture) sensor: 0v with iginition [OFF] and 12.13v with ignition [ON].
- Error Codes: Since before these issues, I've had the error P1457 (small EVAP leak) and within the last few days (after the above issues) received the error P0138 (HO2S Bank 1 Sensor 2 Circuit Low Voltage).
Last edited by takkun324; Sep 13, 2017 at 03:26 PM. Reason: Forgot to add details.
I replaced the thermostat and radiator-thermo-switch.
SOLVED: The temperature gets up to 208 F and then the radiator-fan (and condenser-fan, oddly enough) kick on for just a minute (while idling) until the temperature goes down to 194 F.
