Civic 1990 ee9 ivt hydro gearbox shafts/axel advice needed
Hi guys I have a 1990 Civic ee9 comes with a b16a1 as standard but mine has a b16a from the ef9 I also have a del Sol VTI with a B16 A2 which also came with a s9b LSD gearbox from the Civic aerodeck b18c4 I've put the s9b on the B 16a I just need help with shafts I have Integra Type R 1998 driver side shaft and passenger Civic aerodeck 1998 intermediate and passenger shaft will this be ok any advice would be great as I'm from the UK and I'm not having much luck with advice over here help needed ASAP I still have stock EE 9 shafts but these are stupidly hard to get so if I could buy another shaft that's readily available that would be good for example Civic EG EK Integra which can be bought off eBay
you need to use the shafts that came on the s9b gear box both axles and the center shaft too
all three need to match for it to work
I'm from the UK so the Civic is a right-hand drive and the driver side shaft is a single shorter shaft when I turn left it knocks I've taken that shaft back out put the original Civic ee9 9 ivt shaft back in I'm looking for a replacement that I can use as I plan to take the car on tracks and would like a readily available spares that isn't expensive
Se-rv-Tak
Feb 17, 2004 09:07 AM
