Transmission & Drivetrain Gearboxes, Differentials, Clutches
LX 2006 Manual transmission noise
Old Sep 8, 2017 | 02:08 PM
maminej's Avatar
Default LX 2006 Manual transmission noise
Hello Everyone, I need some advice from the civic 8th gen experts. My 2006 LX has little more that 170K miles, never had any major issues, until around 6 months ago. I started to hear some weird noise coming from the transmission. The car was functioning properly, the transmission in particular was shifting normally. I replaced the Transmission fluid and didn't find any major particles in it so I kept driving. This noise kept going louder and louder to where it became noticeable from the outside of the car. This noise will especially be very loud at the lower gears, and COMPLETELY GOES away when the clutch is disengaged. I was positive that it was coming from the transmission because it all goes away as soon as I press the clutch pedal and king comes back when I engage the clutch.about a month ago, the clutch started slipping at higher gears and the noise became louder at lower gears. The clutch slipping became obvious around last week so I decided to drop the tranny and replace the clutch.
Transmssion
Clutch
I got the transmission out of the car this morning and noticed some noise when spinning the countershaft manually. I can hear some noise as if some bearing ***** were floating inside the transmission. I recorded this video to better explain it :
I ordered a new clutch and it will be delivered tomorrow but since I noticed this noise coming from the transmission, I am worried that the clutch is not the root cause of the problem. And I obviously don’t want to put everything back together and have my new clutch fail again in few months.I wanted to hear your recommendations before opening the transmission housing. I am tempted to open it and confirm if one of the bearings is broken. Please advise !RegardsAJ
Old Jul 15, 2024 | 04:31 PM
thefairarbiter's Avatar
Default Re: LX 2006 Manual transmission noise
I have a similar issue in my own civic around the same mileage. Did you ever resolve this problem? What was the problem and how did you fix it?
Old Jul 15, 2024 | 06:17 PM
Ryanthegreat1's Avatar
It needs input shaft bearings. Very common.
Requires opening the transmission to replace the two bearings. Pretty straight forward. No bearing pullers should be required.
AussieR
Sep 4, 2016 08:30 AM
hondanacura
Dec 9, 2012 04:01 PM
kte324
15
Feb 16, 2010 09:40 PM
UpAndComin
Feb 17, 2009 08:25 AM
red05
Honda Civic (2001 - 2005)
Nov 2, 2007 07:41 PM
