tokico struts vs nuespeed struts?
Old Sep 8, 2017 | 12:03 PM
Alicali's Avatar
Icon6 tokico struts vs nuespeed struts?
hey guys i have nuespeed struts with nuespeed lowering springs and the ride is personally great other hondas ive driven in have been stiff to the point where im catching air on bumps. im just wondering what some of your experiences are with either of these struts, depending on your opinions i will use either struts for the hatch i plan on getting. thanks
Old Sep 8, 2017 | 02:42 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: tokico struts vs nuespeed struts?
Aren't the Neuspeed's just Koni Sport (yellows) with extra height-adjust grooves cut into them (and a droop limiter)?
The Koni Sport's are a better damper than the Tokico Illumina. That may or may not be worth the extra cost to you depending on what you do with your car though. For competitive driving, Koni can be quicker. For daily driving, Tokico Illumina may be worth the savings. Kinda depends.
As for catching air, both shocks are adjustable. The ride quality can be adjusted considerably.
Old Sep 8, 2017 | 03:12 PM
Alicali's Avatar
thanks for the reply ive never tried or thought of adjusting the shocks the ride is like stock as far as comfortability. i have both shocks im riding on th nuespeed right now. and as far as adjusting the struts is it for ride height purposes or stiffness?
Old Sep 8, 2017 | 04:59 PM
94eg!'s Avatar
#1 Super Guy
Loved
It's for stiffness....specifically the shock rebound on Neuspeed Konis. When you spin them counter-clockwise, they get stiffer. When you spin them clockwise, they get softer.
- If you stiffen just the front shocks, you will reduce over-steer and/or increase under-steer.
- If you stiffen just the rear shocks, you will increase over-steer and/or decrease under-steer.
- If you stiffen all shocks, you will increase steering response and ride harshness
- If you soften all shocks, you will reduce steering response and ride harshness
BTW: If you like the current setting, but want to experiment, be sure to write down where the original setting was at. Whenever I adjust mine, I always turn them all the way down first and count the number of rotations to the 1/4 turn. That way I can easily set them back to where they were before I started messing with them. Example: Fronts set to 1 turn from soft, rears set to 1-3/4 turns from soft.
Old Sep 10, 2017 | 01:09 PM
Alicali's Avatar
thanks man ill give it a go.
em2power
Suspension & Brakes
11
Nov 5, 2007 05:40 PM
lswift
Oct 7, 2004 10:35 AM
basmasta7
Dec 12, 2002 07:51 PM
kenshi23
Jan 25, 2002 01:38 PM
wuhungsixxx
Jul 31, 2001 05:42 PM
