Keeping AC: b-series swap into '93 del Sol
Hello everyone.
Im in the process of swapping a JDM GSR into my '93 del Sol. It had an NA built z6 but a valve dropped and destroyed the motor.
The AC still works and I'd like to keep it. What bracket is required to mount the z6 compressor to the b18c block?
Thanks!
Thanks!
you can get the p54 from the DOHC b16a delsol but it is expensive
Same bracket different part # is the 97 crv ac bracket P7J I believe
It cost about half as much as the del sol bracket
roc
Feb 29, 2004 06:01 AM
