What color is wire is for ckp sensor on obd1/obd2 distributors?
Old Nov 11, 2002 | 10:45 AM
cbrman's Avatar
Default What color is wire is for ckp sensor on obd1/obd2 distributors?
I am getting an error code 4 on my p28 ecu and need to know which wire is the crankshaft position sensor. If you know, please post up.
Thanks
Steven
Old Nov 11, 2002 | 02:51 PM
racerxadam's Avatar
Default Re: What color is wire is for ckp sensor on obd1/obd2 distributors? (cbrman)
there should be 7 wires coming out of the dizzy. i'll list the colors like this:
sensor: wire color/stripe color and then the ecu pin
crank sensor: blue/green B15, blue/yellow B16
cyl sensor: orange B11, white B12
tdc sensor: orange/blue B13, white B14
ingition input signal: yellow/green A22
there are two other wires but they match in color to the obd-0 dizzy and are much fatter. they are the wires that go on the separate two pin plug
[Modified by racerxadam, 6:53 PM 11/11/2002]
Old Nov 11, 2002 | 07:37 PM
cbrman's Avatar
Default Re: What color is wire is for ckp sensor on obd1/obd2 distributors? (racerxadam)
sweet thanks racerxadam.
JDMekBoosted
Dec 17, 2008 01:07 PM
redeg61987
Apr 29, 2007 06:58 AM
CrxEDguY
Feb 7, 2005 07:53 PM
raene
22
Feb 19, 2004 08:29 PM
