Honda CR-V & Element 2WD & 4WD Element & CR-V
1999 CR-V has erratic idle when ac is on
Old Sep 4, 2017 | 07:10 AM
breckrider's Avatar
Default 1999 CR-V has erratic idle when ac is on
I've cleaned the throttle body flap and the IACV. If the engine is cold it runs about 1000rpms even with the AC blower and compressor on. As it warms up the idle begins to fluctuate between about 500 or a little lower and up to 1000rpms. When I turn the AC off and the blower off it idles beautifully at about 700rpms. If I turn just the blower on and not the AC it idles at about 500 and runs pretty steady there but may idle up to 600 or so. If course, all of this is while it's not moving and I'm giving it no gas.
Not sure what else to check unless the IACV is just bad. Is there an easy way to check that? The coolant hoses and the electrical connections are a buggar to get to for a short person.
Old Sep 4, 2017 | 08:51 AM
breckrider's Avatar
Default Re: 1999 CR-V has erratic idle when ac is on
Does the 1999 CRV have a mass airflow sensor?
Old Sep 4, 2017 | 09:14 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
No it does not, it has a MAP sensor.
Old Sep 4, 2017 | 09:50 AM
breckrider's Avatar
Could a bad MAP sensor be the cause of the erratic idle or drop in rpms when the AC is on?
Old Sep 4, 2017 | 09:53 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
I'd lean more towards the AC system being the culprit. The compressor engages, the condenser fan kicks on and it's now drawing more power. I would do a search for an AC Idle UP switch or something of the sort which may be faulty and causing your idle to drop too much rather than kick up when the compressor and fan kick on.
Old Sep 4, 2017 | 10:05 AM
breckrider's Avatar
OK. I'll check that.
Rooftop-Special
Sep 2, 2010 08:08 PM
Schultzie
Aug 14, 2008 11:22 PM
blackludebosh
Aug 9, 2008 01:33 AM
liljohnson
Aug 13, 2004 11:23 PM
Jeager521
Sep 12, 2003 12:28 PM
