CRX B Swap OBD0>OBD1 Fuel Injectors
Old Sep 3, 2017 | 07:11 AM
MastaFlyMason's Avatar
Default CRX B Swap OBD0>OBD1 Fuel Injectors
Swapped an OBD1 B18a1 into my OBD0 CRX and I'm not sure what to do about fuel injectors. Currently I am using the OBD0 fuel injectors original to my car but my car is an HF so I'm thinking the injectors aren't big enough. I have the injectors that came on the B18 but I'm not sure how to convert them to OBD1. Can I use my old injectors or do I need to switch? And if so does anyone have a link to do a conversion?
Old Sep 3, 2017 | 10:06 AM
netfreak's Avatar
Default Re: CRX B Swap OBD0>OBD1 Fuel Injectors
There's not much to it. My injectors I think were OBD2 and didn't fit the CRX injector plugs without doing some careful work with a knife. If you move off OBD0 injectors you also delete the resistor box. You basically just make sure the 1 power lead has contact with the 4 injector leads and solder them up.
LSV_REX
May 28, 2008 06:41 AM
Ch3mik
Jun 18, 2007 04:40 PM
beastrx
Jan 8, 2005 02:17 PM
civicefdx
Oct 18, 2004 04:38 PM
