sputtering and burning up gas...
Old Sep 2, 2017 | 08:25 AM
Angela Thomas's Avatar
Default sputtering and burning up gas...
I have a 1990 Honda accord ex. 2.2L. It has a sputtering while running that we cannot figure out. We changed the ignition, the fuel filter, the spark plugs and wires, and drained the gas tank. Code reads oxygen sensor but that's been replaced as well. Any ideas? Please help. Thanks!!! Air filter is clean as well.
Old Sep 2, 2017 | 09:19 AM
somick's Avatar
Default Re: sputtering and burning up gas...
What kind of oxygen sensor did you use?
I would try to clear the code and see what happens.
How does the distributor cap look inside?
Good luck,
Sam
Old Sep 2, 2017 | 10:19 AM
Icon7 Re: sputtering and burning up gas...
Good luck,
Sam
Hi Sam. The oxygen sensor is a Spectra Premium OS5099 Oxygen Sensor I purchased off Amazon. Didn't think to look at the distributor cap because the entire ignition is less than a year old. the code wont clear, even by disconnecting the battery.
Old Sep 3, 2017 | 04:59 PM
Northernlightz's Avatar
Use NTK/NGK oxygen sensor.
sgull
Feb 25, 2013 05:32 PM
Epyon3
Dec 27, 2012 01:00 AM
AC01R1
Jun 24, 2009 10:42 AM
