Symbol Maintenance Items
Greetings from Europe.
Here Acura TSX is called Honda Accord.
Even though some specs are different and could vary by the model and year the basic principles are the same. I have a question regarding reseting the schedule on maintenance screen. Here is the Symbol Maintenance Item (Codes) for the European Accord.
A Replace engine oil and oil filter
B inspection service
2 Replace dust and pollen filter
Inspect drive belt
3 Replace transmission fluid
4 Replace fuel filter
Inspect idle speed
Replace spark plugs
5 Replace engine coolant
7 Replace brake fluid
8 Replace air cleaner element
9 Inspect valve clearance[/size]
Here is the point: Today I changed both the transmission fluid /code 3/ and replaced the brake fluid /code 7/. After resetting /code 3/ the computer moved me to B which is not due at this point so I do not want to reset it because it will mess up the schedule for it. Code 7 was due to change. As a matter of fact, it appeared few months ago. How could I make code 7 appear again on the dashboard and reset it?!
Thanks.
Inspect drive belt
Inspect idle speed
Replace spark plugs
Thanks.
You need to go through the main service manual and see the selection process. It's the same for all maintenance coding. No one, unfortunately, memorizes that process list.
A few sources.
https://carmanuals2.com/acura/tsx-20...s-manual-31800
& here
https://cardiagn.com/acura-tsx-2003-...ce-manual-pdf/
A few sources.
& here
john1233567
Oct 22, 2015 03:05 PM
