2000 Honda civic ignitions switch?
Old Aug 30, 2017 | 06:29 PM
CAPONICA's Avatar
Default 2000 Honda civic ignitions switch?
Car will sometimes keep running when key pulled out, and engine will sometimes stop while driving. Will start agaain after waiting 10-20 minutes, Replace ignition switch???
Old Aug 31, 2017 | 05:19 PM
tamboo's Avatar
10 Year Member
Default Re: 2000 Honda civic ignitions switch?
clean the contacts and see if there's a difference or just replace since it's a known issue.
DIY Ignition switch cleaning - Team Integra Forums - Team Integra
if not here's other likely suspects:
Honda Acura Essential Electrical Repair Website. Troubleshooting Main Relay, Coil, Igniter, etc.
Old Aug 31, 2017 | 05:56 PM
mk378's Avatar
It is typical on old cars for the key and cylinder to get worn enough that you can pull the key out without turning it to the off position.
When the switch is bad causing the car to stall, you can usually re-start it immediately. If the engine stops while driving, and the "oil" and "battery" lights on the dash DO come on after it stops, the problem is likely not the ignition switch. If the lights DO NOT come on, the switch could be bad.
djfrankdatank
Sep 23, 2014 09:05 PM
clifftbrd
Apr 26, 2014 10:50 AM
JuneBugDrfter
Nov 30, 2013 07:57 AM
honda genome
Mar 14, 2007 05:37 PM
honda genome
Mar 14, 2007 05:00 PM
