Wierd problem 99d16y8 swap in eg ex coupe
Aloha everyone its been a long time since i needed help with a project but here i am i have a eg coupe ex auto vonverted to 5 spd i did all the necessary thing to completely it to reverse lights brake Nd clutch switches and no cel problems i also installed a b18c in it later and it was awesome so now im doing the family scene and getting rid of the coupe so i pulled my y8 swap out my ej8 and put it in the coupe to save the gsr so anyway everything went well ( dizzy is y8 woth conversion clip )untill start up at first it did not want to fire the injectors but would spark than i re did the grounds dizzy and and scrubed the connections on grounds with a wire brush but now.... all of a sudden i can get the car to start n run but the temp sensor gauge the rpm gauge has nooo power and i checked all grounds on ecu are strong expect for b1 i go to yhe temp sensor single wire and try n ground it with a light tester and its really dim yhe neddle bounces for a bit than drop doesnt rise up all the way or anything im trying ecerything i can think of but i am just fustrated had to sit down and thought to come amd ask the wall of wisdom plz help guys thank you
driftguy2008
Sep 16, 2012 04:18 PM
binder1er
Apr 20, 2007 06:58 PM
They Call Me Bizzare
Mar 23, 2004 06:12 PM
