Swap help
Have a 95 civic ex with a soch vtech, (D series d16)
in my shop i have a B series b18a1 out of my girlfriend's 91 sedan she scrapped, was wondering of i would be able to swap out my d16 with the b18, it has a obd0 dizzy and pr4 ecu.
any thoughts? Im in the process of rebuilding it due to bad valve guides and piston rings, if i cant swap was going to donate too a friend.
Thanks :D
Thanks :D
It would be a lot of work to turn your '95 civic into an OBD-0 engine management system... you are much better off to get OBD-1 LS parts (distributor, ECU and fuel injectors minimum) and make your life easier. Also, you would be better served to find a hydro "B" transmission instead of using the OBD-0 cable trans and a cable-to-hydro conversion kit.
