Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic 2003 EX - Which catalytic converter to buy?
Old Aug 26, 2017 | 11:53 AM
sharaaz2001's Avatar
Icon6 Civic 2003 EX - Which catalytic converter to buy?
I am not sure if there are two catalytic converters (CC) in my Honda Civic 2003 EX Coupe. I want to order, but some places also talk about a manifold CC, which others only say I need a under-carriage one. How do I determine if I have two CCs or just one, and if so which one?
Any pointers for this rookie, will help.
Thanks
Old Aug 26, 2017 | 04:35 PM
prodjay10's Avatar
Default Re: Civic 2003 EX - Which catalytic converter to buy?
It should only be one cat that is also the exhaust manifold.
Old Aug 26, 2017 | 09:30 PM
Not sure what you are saying. I know that there is a catalytic converter under the car (See pic 1 below). Then there is another one that car part sellers sell for the same model (See pic 2). If there is only one, which one is the one I need for me car. Can't get an answer for this anywhere.
Old Aug 27, 2017 | 05:47 PM
toyomatt84's Avatar
Sanji
You need the top picture one. You do only have one catalytic converter. That bottom picture is for Civics the model 7th gen Civics that have a D17A1 (non-VTEC model). Your EX has a D17A2 (VTEC model) engine with the two-part manifold assembly.
Old Aug 28, 2017 | 08:25 AM
Thank you, toyomatt84. This is very helpful.
Sharaaz
Old Sep 5, 2017 | 07:37 AM
solex's Avatar
I'm in the process of doing this now with my 2003 EX. Replacing the CAT and the resonator tube. The flange where the two are joined was completely rusted and fell apart last week and there is a hole in the CAT.
I purchased the MagnaFlow cat mid-pipe as it is mandrel bent (the diameter is consistent throughout the entire pipe) like the original but it is stainless and $400.00 USD cheaper; the only caveat is that it is not CARB compliant.
I purchased the OEM resonator as I did not want to replace my muffler and painted it with VHT paint and got all stainless hardware.
Yesterday I removed the resonator and loosened the CAT tube and the two OXY sensors. I recommend using PB-Blaster on the spring bolts for a few hours and do recommend replacing with
 Walker 35129 Exhaust Spring Bolt Kit Walker 35129 Exhaust Spring Bolt Kit
, as it has a 15 mm head instead of the std 12 mm. I had to to bang on and 11 mm socket in a couple of cases as the 12 mm bolts were rusted down.
All parts (gaskets, MagnaFlow, spring bolts) were sourced from Amazon except the resonator which was purchased from Majestic Honda.
Amazon Shopping list:Cheers,
Dan
Old Sep 18, 2017 | 09:41 AM
solex's Avatar
Finally finished this weekend everything from the mainfold was replaced and painted with VHT silver, except the CAT as it is all stainless.
Zlehman83
Apr 6, 2016 04:03 PM
wrosenst
Feb 1, 2013 01:07 PM
shorty5198
Oct 16, 2006 08:52 AM
projectEK9
Feb 27, 2005 05:28 PM
