Transmission & Drivetrain Gearboxes, Differentials, Clutches
Accord 96 Automatic Trans TCM problem
Old Aug 25, 2017 | 04:43 PM
Sebastian Reyes's Avatar
Default Accord 96 Automatic Trans TCM problem
Hello, first of all, sorry for my bad english... im from Chile and i search for some help in my accord!
I have a '96 european Accord h23a3 with automatic transmission problems, the car starts move in 2nd or 3rd in D4 (like limp mode), 2nd and 3rd works perfect manually by the shifter, but i dont have the 2 seconds S light on the dashboard when i turn the key on ignition, (D4 light in some models) so i cant get any codes... (obviusly sport mode doesnt work and light dont turn on by the button) it seems that is a electrical problem... so i found that the TCM doesnt got voltage from ignition in the a23 and a24 pins, conclusion... the TCM has no voltage or no alimentation, i check all the fuses, wiring diagrams... everything except the wires... I make a bridge between ignition and the alimentation a23 pin and EVERYTHING WORKS PERFECT... my question is if someone has the same problem, does the voltage passes from ignition to another component? any solution?
dougaccordwagon
Jul 19, 2016 09:55 PM
djjosehernandez
Jul 12, 2009 03:11 PM
Findingo
Sep 1, 2005 08:15 AM
rohsaew
Oct 29, 2004 09:51 AM
