needing insight for my jdm sohc? zc
Old Aug 22, 2017 | 03:12 PM
enox's Avatar
Default needing insight for my jdm sohc? zc
so I have a sohc(I believe) zc block with a y7 head and I'm almost positive the trans with it is the original. seems to lack pull in low rpms until around 3k, almost does a hiccup from a dead stop (maybe I'm still not accustomed to the honda clutch but idk) I've had the car for a year now. I've replaced the clutch, throw out bearing, pinion bearing, flywheel, and rear main seal (previous owner said it was leaking) along with the oil pan gasket.
I am curious if the ecu and or flywheel are giving me grief with this current build. or if the trans gears just aren't up to par for the sohc zc block. also I believe its an obd2 engine but I'm not positive and I really don't know how to tell. not sure what the problem could be or if it's even fixable.
any insight is most appreciated. thanks in advance! block code?
trans sticker
ecu i believe
trans vin #
dash vin
Old Aug 23, 2017 | 07:15 AM
enox's Avatar
Default Re: needing insight for my jdm sohc? zc
bump
GeoMetry
13
Nov 8, 2015 03:20 PM
TravisCadello
19
May 20, 2009 09:17 PM
89 pos
Apr 28, 2005 08:22 PM
Ecugrad
Apr 12, 2005 05:11 PM
dingusjt
Mar 28, 2004 10:10 AM
