Honda CR-V & Element 2WD & 4WD Element & CR-V
04 crv shaking
Old Aug 21, 2017 | 02:52 PM
aderyas's Avatar
Default 04 crv shaking
my 04 Honda CRV shaking in speed 50 to 60 MPH, happened after changing transmission fluid, differential fluid, tire changed also 2 times. pepboys told me i need to change both front axle, a family michanic told me the drive shaft is the one need to be changed. which one i have to believe?
Old Aug 22, 2017 | 03:07 PM
Occidentalis's Avatar
Default Re: 04 crv shaking
It sounds like front CV axles to me, but you can easily check if it's the drive shaft by removing it and seeing if the shake is gone. Probably worth checking the motor mounts as well.
Old Aug 23, 2017 | 09:03 AM
KINgJ8's Avatar
CV joints/axles or maybe the tire balancing?
wgbm92
May 17, 2012 12:48 PM
xlusiveracer
10
Jan 17, 2006 10:22 AM
EVIL_AWD
May 24, 2003 06:28 PM
EVIL_AWD
May 24, 2003 06:04 PM
B18C-RnVA
Sep 22, 2001 01:48 PM
