93 GSR b17 cranks but no start
Old Aug 19, 2017 | 01:12 PM
JDMcupcake405's Avatar
Default 93 GSR b17 cranks but no start
93 gsr 1.7l
fuel pump went out, we changed that, new fuel pump went out, changed it again.
everything is it working order. But wont start
fuel pump is priming, have good spark, dizzy is good, cap and rotor are great, timing and compression all good. Tried pop starting it and it turns over but not run. We have tried everything.
Old Aug 19, 2017 | 09:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 93 GSR b17 cranks but no start
You are missing something... you need fuel delivered at the proper time, spark at the proper time, and the engine must be in proper mechanical time... and with airflow... WILL run. You have stated that you have all of these... which means it will run... but it doesn't. Check ALL critical items again.
Old Aug 20, 2017 | 06:28 AM
The only thing we can think of is the ECU... we have fuel in the injector rail, but no fuel on the plugs. Thinking the injectors ore not opening up.. is there a way to test the injectors?
Old Aug 20, 2017 | 01:43 PM
theYBLEGAL's Avatar
Loved
Injectors are wired directly to the ECU.
Old Aug 20, 2017 | 04:02 PM
Hollapeña's Avatar
open up the ECU and look for rust spots on the board...might ease your mind a little bit
Old Aug 20, 2017 | 05:55 PM
Update:
just installed new ecu.... still tries to start but just wont fire up.
Old Aug 20, 2017 | 09:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Check your main control ground for the ECU found on the engine harness... it should bolt to the thermostat housing with a 6mm bolt (10mm head). Also, if yours is currently connected and tight... remove it, scrape the metal surface of the housing clean, and then re-install. Then make sure you have the ground between the right frame rail and the transmission case connected as well as the ground wire between the valve cover and the front core support.
Steven.Seale
Jun 18, 2022 08:28 AM
Jamalot
Sep 5, 2015 12:58 PM
lifethinker
Apr 21, 2014 01:04 PM
TORTUGA
19
Aug 28, 2013 03:08 PM
mlb4046
Jan 23, 2011 03:53 PM
