how difficult would it be to replace the water pump in a 1992 accord
how difficult would it be to replace the water pump in a 1992 accord?
I have a 92 accord 4cyl with around 370000 km on it. The pump has a steady coolant leak and i don't really want to pay 500-600 to have someone do it for me. Im not a mechanic but i can do the simple stuff.
any tips?
any tips?
well it's easier than replacing the timing belt since the old belt will be fairly easy to put back on when you replace the water pump
you can use this as a guide, it's basically the same, the hardest part is really just getting the crank pulley bolt off but nowadays most part stores rent out the Honda Crank Pulley Holder tool
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/
The thought occurs to me that people usually replace the water pump when they replace the belts. How long since the belts were replaced?
jeffreylee67
May 30, 2013 04:36 AM
exs1995honda
Jul 24, 2010 12:33 PM
unhappy_idle
May 22, 2006 10:16 AM
