Civic 6th Gen... Lower Control Arms
Good question. I don't know the (full) answer but according to hondapartsnetwork.com the stamped steel ones weigh roughly 1 Kg less (6.5 vs 5.5 Kg). That's one advantage.
Also I've heard people say they prefer the sway bar end links used with the stamped steel arms, although I don't know the technical reason why.
Just as a curiosity AFAIK all Japan-built 6th gen Civics came with the stamped steel arms.
The 6th gen Civic was designed after the Japanese economic bubble burst so I don't know if the switch to stamped steel was technology- or cost-driven, or maybe both?
The end links on the stamped arms are a double heim joint style, so they are zero-compliance as opposed to the typical Civic ones that have a stack of soft rubber bushings at the ends or the Integra ones that mount to the arms with bushings and to the bar with a heim.
Curious to know... Does the stamped steel ones move less than the 2pc ones? I see many different traction bars for the 2pc design, but almost nothing on the stamped steel.
(I know there are other ways to reduce wheel hop; stiffer motor mount and control arm bushings.
I'm going to go out on a limb here and take a guess but...
Every traction bar setup I've seen or dealt with bolts to the LCAs where the halves bolt together. The stamped arms are one-piece, so there's nowhere to bolt the links to. Pretty sure that's the whole story.
ke98248
Apr 2, 2008 05:16 PM
TraKtioN
Dec 28, 2007 02:43 AM
87REX_Si
Mar 3, 2006 12:58 PM
