what to do with transmission ?
Old Aug 13, 2017 | 08:10 PM
sr20paisa's Avatar
Default what to do with transmission ?
So I recently picked up a rebuilt y1 cable trans, and after reading up on the early cable (non lsd) b-series transmissions, I found out that they have a habit of puking their diff pins out and destroying the case due to the spider gears chewing through them. So I have a few methods in mind and I would like to see what some of you guys have to say about them
method 1: spot welding diff pin to the differential itself
method 2: sourcing a "strengthened" 92- up diff pin
method 3: combining both method 1 and 2 if possible
method 4: some how figure a way to shoehorn in an itr lsd
also open to more methods thanks
Old Aug 14, 2017 | 03:04 PM
sr20paisa's Avatar
Default Re: what to do with transmission ?
will a itr lsd diff fit the b16 ring gear?, seeing that the are both 10-bolt but have different bearings
Old Aug 22, 2017 | 08:25 PM
sr20paisa's Avatar
imma just try mthod #2, anyone have any input before hand?
Old Aug 23, 2017 | 02:11 PM
Creator's Avatar
Not sure if it has the same shifter fork setup as the J1 trans, but there was a weak point on the 3-4th shifter fork.
Obviously I had a J1, it had a quaife LSD that has since been moved over to a YS1 trans. Not sure that helps much but...
Old Aug 23, 2017 | 05:19 PM
sr20paisa's Avatar
hopefully thats not a problem for mine, thanks for the input anways though
92integraVTECgsr
Nov 29, 2005 02:06 PM
jDMJeRk
Dec 23, 2003 07:31 PM
bigdahlers
Jan 31, 2003 05:33 PM
evo
14
Aug 3, 2002 05:53 AM
