most torque you have ever seen out of a B18C1...
Old Nov 11, 2002 | 07:40 AM
Ohlias's Avatar
Default most torque you have ever seen out of a B18C1...
I want to see some tourque numbers from NA GSRs. Preferably OBDII, and what they did to achieve this. Also, if you guys have any experiecne you want to share....
Basically I want to change my Cat and exhaust at the beginning of summer, and next year when my warranty is up, I'll probably get a header. I want to be heading in the right direction in order to get some more torque to the wheels. I don't need to go 240kmh++, just want to get there faster
Thanks
[Modified by Ohlias, 1:20 AM 11/12/2002]
Old Nov 11, 2002 | 08:00 AM
metal-x's Avatar
Default Re: most torque you have ever seen out of a B18C1... (Ohlias)
www.importreview.com
check on the dyno results
Old Nov 11, 2002 | 01:29 PM
Ohlias's Avatar
Default Re: most torque you have ever seen out of a B18C1... (metal-x)
thanks...
Old Nov 11, 2002 | 01:46 PM
Anyotherone's Avatar
I've seen several dynos of bored out 2 liter b18c's that were pushing 160wtq.
Old Nov 11, 2002 | 03:08 PM
OBDI JEDI's Avatar
Default Re: most torque you have ever seen out of a B18C1... (Anyotherone)
street or strip?
Old Nov 11, 2002 | 03:40 PM
awskalis04's Avatar
Default Re: most torque you have ever seen out of a B18C1... (OBDI JEDI)
nvm
[Modified by awskalis04, 6:46 PM 11/11/2002]
Old Nov 11, 2002 | 09:20 PM
Ohlias's Avatar
Default Re: most torque you have ever seen out of a B18C1... (awskalis04)
NA Daily driven (street).
Old Nov 11, 2002 | 09:28 PM
Halo's Avatar
what's the budget? staying stock bore?
Old Nov 12, 2002 | 02:41 PM
Ohlias's Avatar
Default Re: most torque you have ever seen out of a B18C1... (Halo)
No budget in mind, just don't want to go crazy. I'd like to be buying a house within the next 2 years. let's say 3 grand inluding cat ehaust and header...
I just want to maximize the amount of torque and midrange. Basically I find the GSR already has plenty up top, I just want more grunt down low and would like to make the best of it.
Thanks
Old Nov 13, 2002 | 06:30 PM
awskalis04's Avatar
drag racing, kenny tran has 500 lbs of torque on his b18c1
Old Nov 13, 2002 | 06:35 PM
Tomakit's Avatar
what part of NA gsr did you not understand about the original post?
Also, got any scans of those 160 tq graphs? 150 seems hard to come by in a 2.0 ltr...
Old Nov 13, 2002 | 07:16 PM
The Rob's Avatar
Default Re: most torque you have ever seen out of a B18C1... (Tomakit)
That what I was thinking. I know its OT, but I've seen LS's put down 140tq on stock bottom end.
Old Nov 13, 2002 | 09:43 PM
jeebusm3's Avatar
Default Re: most torque you have ever seen out of a B18C1... ( Zero)
if you really wanted torque you probably shouldn't have gotten a honda.
Old Nov 14, 2002 | 04:52 AM
QCKGSR's Avatar
i have 145lbs to the wheels through a 1.8 b18c just cams, portwork, hondata , injectors ,ihe
Old Nov 14, 2002 | 05:39 AM
Here's a link to one, just off the top of my head, I'd have to look around for the others I've seen.
Old Nov 14, 2002 | 05:40 AM
I'm going to take this route with my car, only with Toda A's or Skunk stage1's...
Old Nov 14, 2002 | 07:29 AM
Archidictus's Avatar
Unceasing Measure
Is it the cams that are killing the torque at VTEC crossover? I'll bet that feels kinda weird...right before it rips your head off
edit: anybody know what compression she's running?
[Modified by Archidictus, 11:30 AM 11/14/2002]
Old Nov 14, 2002 | 07:51 AM
skunked's Avatar
I had 141tq on a stock sleeved GSR block with USDM ITR pistons.
with a 84-85mm you ar capable of 150-165tq.
Old Nov 14, 2002 | 06:32 PM
awskalis04's Avatar
i donno what NA means
[Modified by awskalis04, 9:32 PM 11/14/2002]
Old Nov 15, 2002 | 10:24 AM
Ohlias's Avatar
Normally Aspirated. I.e Breathing unforced air air. Turbo or SuperCharger would be FORCED Induction. The air is being "sped" up and pushed into the throttle body..
Old Nov 15, 2002 | 10:30 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i got 112.8 =P
Old Nov 15, 2002 | 10:43 AM
ShootingStar's Avatar
Default Re: most torque you have ever seen out of a B18C1... (dLo GSR)
I hit 125.6 on my '94 GS-R in March... 135k miles, IHE, CTR cams, VAFC, B&M FPR
Old Nov 15, 2002 | 12:45 PM
allenp's Avatar
Well, not really sped up, but rather pressurized... More air is flowing into the cylinder due to a higher pressure at a given flow rate...
But I'm really picking nits...
Old Nov 15, 2002 | 12:56 PM
Tony the Tiger's Avatar
Default Re: most torque you have ever seen out of a B18C1... (allenp)
I had 219 WHP and 145 WTQ with my NA 1.8L B18C1 -- 12.2:1CR, TODA B's, HyTech header, etc...
Old Nov 15, 2002 | 01:12 PM
Default Re: most torque you have ever seen out of a B18C1... (Tony the Tiger)
Wow, I wonder how much you could have pulled with that bored out to 84.5mm
