New dizzy yet NO SPARK! Need HELP!! SO Stumped!
So about a month ago my dizzy crapped out on me so I bought a aftermarket one on amazon. Two weeks later I park the car and didn't drive it for a week. When I went to start it, it just cranked and didn't start. So I tested for spark with a spark tester and no spark. So I ordered another distributor, installed it once it got here and the car didn't start at all (no spark with spark tester). So today I tested the wire from the ecu on the dizzy plug and I was getting power, also took cap and rotor off so I could see if I was getting power to the coil and it was. Both of the new distributors I tested the coil and got .9 ohms. Now I read it should have been between .06-.08 ohms . Would that deem both coils no good by just being out of spec by .1? Now I haven't tested the ICM yet so help with that would be appreciated. Any help is appreciated. By the way its a 98 EK with JDM H22 converted OBD1
Does the ECU boot up (CEL cycle on and off, fuel pump prime) when you turn key on but don't crank? Does the distributor rotate when you crank? Note that you should never fire the coil into an open circuit. Any time you crank with the cap off hold a grounded wire near the coil output. You should get blue sparks that jump more than 1/2 inch.
I seen a video on You tube that says if I put the test light on the negative side of the coil and start it, the light should pulse meaning the ICM is working properly. Does that sound right?
Yes, .1 OHM outside the test window means it is bad.
I am curious... why do you replace the entire distributor when the problem is only the coil ??? If you weren't getting any distributor sensor related codes (4,8, or 9) for TDC, CKP or CYP, I suggest you simply replace the coil inside the original H22 transmission with a genuine Honda part and stop buying that crap online. Aftermarket Honda distributors have a history of being a POS.
fatjoe2174
Jun 6, 2005 01:53 PM
projektCRX
May 27, 2004 11:19 PM
