Two valve cover bolts stripped
Old Aug 12, 2017 | 01:36 PM
Casey Enk's Avatar
Default Two valve cover bolts stripped
I have an 01 Accord with a front and back valve cover bolts stripped, we think this is reason for oil leak any ideas on a simple fix
Old Aug 12, 2017 | 01:46 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Two valve cover bolts stripped
If the threads are only stripped, and you do not have many tools, try using Permatex or Loctite stripped thread repair kits.
Old Aug 12, 2017 | 02:18 PM
Casey Enk's Avatar
The bolts keep spinning after the initial tighten down so we believe whatever they go into is stripped
b.zuller07
Nov 11, 2018 08:04 AM
mike03,95civic
Dec 12, 2008 01:39 PM
PatrickGSR94
Nov 15, 2008 05:40 PM
NiBlazed
Dec 19, 2004 08:33 AM
crxaddikt
Sep 19, 2002 10:08 PM
