Gsr hydro trans internals into ys1 cable trans question
Old Aug 11, 2017 | 08:51 PM
nicknack25's Avatar
Default Gsr hydro trans internals into ys1 cable trans question
So i've swapped 2001 gsr hydro internals into my ys1 cable trans years ago, and i remember reading about shimming the differential or something, but I remember not knowing how to do it so i skipped that part. Everything ran fine though, but i'm about to pull out my tranny to replace the input shaft bearing aka clutch housing bearing, so i figure i should probably shim it or at least check the clearance. Problem is, i can't find the forum i used as a guide.
Does anyone know how to do this or even have the specs?
hwt101
Dec 2, 2008 10:46 PM
matt da jdm junkie
Jul 25, 2008 11:43 AM
NFJohn
May 27, 2004 05:40 PM
