Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic 2001 - Primary O2 Sensor Heater issue
Old Aug 10, 2017 | 01:19 PM
Eduardo Escobar's Avatar
Icon5 Civic 2001 - Primary O2 Sensor Heater issue
Hi there, i'm new to this forum.
I have a 2001 Honda Civic 1.7L LX, manual transmission, D17A1 engine.
Some weeks ago the check engine indicator of my car popped up, used a ELM327 scanner interface which told me there was the following fault error: P0132 - O2 Sensor Circuit High Voltage Bank 1 Sensor 1.
I researched a little and found out it was related to the Upstream O2 Sensor (located in the exhaust manifold, before the catalytic converter). Went to the autoparts shop and bought a new one - yes, i have to admit that i had to perform tests on the old sensor to find out whether it was damaged or not... Anyway, i replaced the sensor, cleared fault errors in ECU/ECM, made a new scan and the following fault code was thrown: P0135 - O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1, check engine indicator is still there, so far, although it goes off eventually while driving.
I unplugged the sensor and made some voltage tests on the car's connector's terminals (not the sensor's connector). According to the following diagram:
Test 1: Battery's negative terminal against connector's ~ +12V terminal, result: tester displays 12.77V.
Test 2: Battery's positive terminal against connector's GND terminal, result: tester displays 0V (it blinks -0.01V, -0.02V).
So i'm guessing there is a problem with the connector's GND terminal / cable, however i'm stuck at this point. What test should i perform now? I've read somewhere that this cable comes from the car's ECU/ECM, but i'm not sure about messing with that one. I'm not a tech guy, i do have some electricity knowledge and i thought it was gonna be enough to fix it by myself.
If someone can enlighten me i'd appreciate it a lot. Thanks!
Wildemanam
Honda CR-V & Element
Jan 30, 2018 08:58 AM
grndslm
Jul 5, 2012 05:11 PM
hondaaccord94
Mar 26, 2005 07:40 PM
mickey513
Jun 2, 2002 04:42 PM
