Suspension & Brakes Theory, alignment, spring rates....
coilovers-need tips on pushing sleeve into top hat!
Old Aug 10, 2017 | 11:02 AM
wolf359's Avatar
Icon5 coilovers-need tips on pushing sleeve into top hat!
I just got my gc/koni yellows and getting that little metal sleeve into both of the poly bushings in the top hat are a pain. Does anyone have a tip on how to easily do this?
Old Aug 10, 2017 | 11:35 AM
KoRn_vIRuZ's Avatar
Default Re: coilovers-need tips on pushing sleeve into top hat!
Stock dampers have 10 mm diameter shafts, Koni yellows have 12 mm shafts. Maybe some grinding is needed to accommodate the larger shaft? It's been a long time, can't recall exactly.
Old Aug 11, 2017 | 03:48 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
If they're just poly bushings....you need to grease them up and push the sleeve thru.
ITR/S2000/TL-S bushings are the ones that need to be drilled out.
Old Aug 11, 2017 | 06:26 AM
wolf359's Avatar
I took an exacto knife and shave just a wee bit of cone in the hole so as the sleeve came through the bottom bushing, it would be able to start to enter the top bushing. That worked like a champ. I used grease, really hot water, brute force, etc. They would just not go in. Once I shave off just a little so the sleeve with a little taper, it went in just fine.
Old Aug 14, 2017 | 09:28 AM
TunerN00b's Avatar
Long bolt, 2 large washers, pair of wrenches.
Or a bench vice if you have one, though I would use some wood to protect things from direct contact with the vice jaws.
snowboardgeek1
Suspension & Brakes
58
Jun 10, 2007 07:12 AM
Tyson
Suspension & Brakes
Oct 4, 2006 01:40 PM
ophdehEEzY
Dec 29, 2003 08:19 PM
ludemonkey
Jun 10, 2003 07:29 PM
taytay333
Mar 26, 2002 03:54 PM
