Help!?? B16a obd0 crx running like crap
So I've been trying on and off for 2 months and I'm getting to the breaking point. A few friends of mine swapped my car it ran fine for 25 miles except a tick in the head but the it started to miss while we were cruising on the highway then died about 7 miles later, after then it sat for awhile I replaced the dizzy and still didn't start so I got towed to my house, we found out the timing was off by 1-2 teeth so we fixed that had about 160-175psi of compression in each cylinder. We let it sit for awhile again and got it to start but rough and would cut out if you gave it too much throttle like it was cutting fuel but some times slowly and roughly go up and idle was around 1,500rpm then usually lowered to normal but was still rough, checked the tps sensor and map and maf sensors were in the right place. Was Throwing a code 14 or 10 and a 4 then just a few days ago it just threw a 10.. made it around my block once but it died once it got in my driveway, injectors are good. One sprays a little less than the others but barely noticeable. Need help please? Will post videos soon!
Clash0901
27
Dec 6, 2011 08:50 AM
Bob_760
10
Oct 11, 2006 12:20 PM
BlackLudeSi
11
Apr 10, 2006 08:02 PM
Hondzas
Oct 26, 2003 11:52 AM
