Selling my swap, opportunity to go k has come up. Located 45min south of Milwaukee. Asking $2500obo. Motor is very strong. Doesn't burn or leak any fluids. 262-325-4157.
B18c1 gsr 700 miles tops
Tuned by mikey in Chicago 195whp/135tq
LS crank/LS rods/b16 pistons, new oem rings/rod bearings
arp rod bolts and head studs
Gsr head, rebuilt with same miles as block. New gsr valves.
Ctr cams
Dual valve springs
Titanium retainers
New valve guides
Skunk2 manifold
Skunk2 Throttle Body
Short ram intake
Aem fuel rail
Rdx injectors
Tuned on chipped Neptune ecu
Skunk2 alpha header
Hasport mounts
Itr linkage
Flp shifter
T1r exhaust
98 spec ITR transmission with LSD
No grinds or pop outs, very smooth trans
Newer exedy stage 1 clutch
Act lightweight flywheel
New axles
