how do you find loose suspension parts?
both my tsx and RL are having suspension issues
and both clunk when i go over a bump
i found and fixed few issues but still clunks
rl i already found and replaced bad lower ball joints that were clunking but theres still noise
tsx i replaced rear sway bar links and bushings but theres still clunking front and rear
i lift the car and try to wiggle all the parts by hand or just bounce the car when on the ground but cant seem to locate any loose parts
anyone got tricks to find the clunking parts? i dont have a lift just jackstands
jack the car up, grab the wheel at 9 and 3 o'clock, wiggle back and forth. if there's play, there's an issue with tie rods. now grab the wheel at 12 and 6 o'clock and wiggle harder. if there's any play, that's balljoints or strut mounts
A rubber mallet is helpful.
Jack it up, make sure it's secure/safe. Grab each and every component and try to move it.
My latest knock noise was a little hard to find. It was the steering rack itself, I can grab my new inner tie rod end, and move the whole sliding mechinisim back and forth, front to rear of car, not sliding like making a turn, a 1/16 of an inch or so. Can kind of make it knock by hand but takes muscle!
Accorddude
Aug 19, 2003 07:25 PM
