2002 Honda accord cranks, but will not start.
Old Aug 5, 2017 | 05:59 PM
SentinelK151's Avatar
Default 2002 Honda accord cranks, but will not start.
My 2002 Honda Accord Value Package, 4 door , 2.3L 4 cylinder, cranks but will not start.
I just did a simple tune up, changed the spark plugs, the wires, and the distributor cap because the inside was worn, at first, she ran fine.
But as the day went on it sounded like the engine was misfiring, the car was having trouble keeping a stable RPM, I got it home, checked that everything plugged in correctly , which to the best of knowledge, it was.
Now it wont start, its cranking, but wont turn over.
It shouldn't be a starter problem, that was recently replaced.
If I could get some advice on the manner, I would really help.
Old Aug 6, 2017 | 03:52 AM
user456101's Avatar
Default Re: 2002 Honda accord cranks, but will not start.
I suggest watching Scotty Kilmer YouTube video "Fixing a car that cranks but doesn't start up". It may be the fuel pump has died. It could be that the fuel injectors are clogged (unlikely).
Old Aug 6, 2017 | 08:42 AM
origamy's Avatar
Coil or ICM most probably. Check for spark first.
timpletcher
Feb 14, 2021 06:44 AM
Bienval23
Aug 18, 2014 12:14 PM
nc2wheels
Jan 23, 2013 11:11 AM
