Transmission & Drivetrain Gearboxes, Differentials, Clutches
98' spec ITR trans- How do the internals look?
Old Aug 5, 2017 | 12:10 PM
S2k@9K's Avatar
Default 98' spec ITR trans- How do the internals look?
Hello, I have a 98 spec JDM ITR transmission. Not sure if I'm going to rebuild it for myself or sell it! Can someone help me identify what needs to be replaced and/or if it would be ok to install as is for a while longer. Pics were taken from low to high. Thanks!
1st/2nd
3rd/4th
5th/Reverse
Old Aug 11, 2017 | 10:49 AM
S2k@9K's Avatar
Default Re: 98' spec ITR trans- How do the internals look?
Bump!
Old Aug 11, 2017 | 11:01 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You sure that's an ITR transmission?
Old Aug 11, 2017 | 11:31 AM
S2k@9K's Avatar
Yes! It is stamped LSD N3E. I originally took the cover off just to count the teeth on the FD and it is the 4.785. Did not appear to have been opened previously or tampered with prior.
Old Aug 12, 2017 | 06:46 PM
94EG8's Avatar
Seagull Management
Overall it doesn't look bad. 2nd gear engagement teeth are starting to get rounded over a little, this can be cleaned up with a flap wheel on a die grinder. 3rd/4th hub and sleeve are banged up and should be replaced. 4th gear engagement teeth should also be cleaned up a little.
Old Aug 12, 2017 | 06:54 PM
S2k@9K's Avatar
Thanks for the reply! I know it can be tricky telling from pictures but, that coincides with what a friend told me also! I was just looking for a little more confirmation on the matter!
Thanks again, Matthew
Rishiras
Nov 9, 2010 03:44 PM
killerpenguin21
Feb 13, 2008 06:29 AM
Parker.
Dec 16, 2007 11:28 AM
43!
Aug 27, 2006 07:36 PM
