Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Car Idles Rough When AC is on. AC won't turn off.
Old Aug 4, 2017 | 04:59 PM
Bobs2008Civic's Avatar
Default Car Idles Rough When AC is on. AC won't turn off.
The AC - of my 2008 Civic - stopped working so my son replaced the compressor/clutch. Now the AC wont turn off, it idles very rough, and surges when moving. Seems like something is causing the clutch to engage and disengage randomly. This only happens when the AC is on... I know this because when I pulled the relay, the engine purrs like a kitten.
The refrigerant level is fine. The car gets cold. A new relay didn't help. Not sure what to look at next.
Old Aug 5, 2017 | 05:39 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: Car Idles Rough When AC is on. AC won't turn off.
My car Ac is good and when I am at a light or stopped and the Ac cycles makes the car engine vibrate and idle drops for a second. Seems normal to me. This will also cause the car to try to surge forward when stop when it clicks on, as the idle compensates.
If the Ac is staying on all the time, you might have some type of electrical or ac/clutch issue.
Old Aug 5, 2017 | 07:31 PM
holmesnmanny's Avatar
check the clutch air gap
Old Aug 6, 2017 | 04:19 AM
The compressor/clutch are brand new. My son thought it might be bad so he took it back and got another. Same story.
Old Aug 6, 2017 | 01:12 PM
your original post is hard to understand cause you say the ac won't turn off but the compressor keeps engaging randomly
can you be more specific and detailed about whats happening
Old Aug 6, 2017 | 03:32 PM
prodjay10's Avatar
My guess is that he's talking about the compressor cycling on and off.
Old Aug 7, 2017 | 06:39 AM
holmesnmany - Yes sorry, somewhat confusing.
Yes, the AC cannot be turned off. The AC button does nothing. When the car starts the AC is engaged all the time. Now, while the car is running, the idle hunts up and down by as much as 500 rpm. and when the car is moving, the engine will surge and pull back in response to the rpm fluctuations. I think that this is the AC clutch going in and out but it may be something else. This has been happening for about 2 years before the compressor/clutch gave out.
When the engine is cold, the car runs smoothly. However as it warms up the idle problems surface.
Old Aug 7, 2017 | 11:10 AM
if the clutch never shuts off then you need to disconnect the coil connector, if the clutch is still on then you need to check the clutch air gap, but if the clutch disengaged then the ac relay is likely bad stuck in the on position, which means it's an Omron and needs to be replaced with the Mitsuba one which is a known issue with these cars
Old Aug 7, 2017 | 11:35 AM
I'll try to disconnect the coil.
I did disconnect the relay and the clutch disengaged. I replaced it with an Omron which didn't do anything. Maybe I should look for a Mitsuba?
Old Aug 7, 2017 | 02:51 PM
you said you disconnected the relay and the clutch disengaged but when you replaced the relay it engaged again ? is the defroster on ? the ac actually turns on when you have the defroster on, most people don't know this
Old Aug 7, 2017 | 06:12 PM
When the car is on, the AC is on except that the clutch will constantly engage and disengage. There is no way to shut it off using the HVAC control panel. Fan off, green light off, no defroster etc. The only way to stop it is to kill power to the clutch like removing the relay or to shut the car off.
So basically the AC is always on but the clutch engages and disengages constantly causing the idle to jump all over the place.
Old Aug 7, 2017 | 06:25 PM
when you say you replaced the relay with an Omron, was that a different one that the one that was originally in there or you put back the Omron ?
if it's a new one and still doing it then something is giving power to the relay when the ignition is on, are the fans also running when it's acting up ? if they are then I gotta think it's the climate control unit sticking on with power to the ac system
i think if the ecu was telling the system to turn on then it would adjust the idle accordingly so it's likely downstream of the ecu
Old Aug 8, 2017 | 08:30 AM
foumer's Avatar
This weird thing has happened to me a couple of times. Car sat overnight, then when I went to turn it on, the AC would engage. No matter if the fan was off or AC button off or defroster button was off. I would assume that it was the relay, but it has only happened to me a couple of times.
Old Aug 9, 2017 | 05:33 AM
After an extensive investigation I am going to try:
  1. Check if the there is too much refrigerant . I have read in older threads that this could cause the rough idle.
  2. Pull the connection to the climate controls. I am not sure that this will help because when I push the AC button, the led goes on and off. However the led could be the only thing working on this system.
FatboyNYC
Honda CR-V & Element
Jul 11, 2018 01:45 AM
tontontons
Jul 14, 2016 01:18 PM
Robert04accord
May 29, 2014 04:39 PM
PL_RACER
Jul 24, 2012 07:20 PM
adan CRX
Nov 26, 2003 08:41 AM
