Broken Bolts That Hold Sway Bar Bushing Now What? 1997 Honda Civic
Old Jul 30, 2017 | 09:28 AM
lindylex's Avatar
10 Year Member
Default Broken Bolts That Hold Sway Bar Bushing Now What? 1997 Honda Civic
How do I get these broken off bolts out? This work is being done curbside. I am not sure if I will have much success with a drill since I can not really get myself lined up well to do this because of clearance.
The highest I can go is with my 4 ton jack.
Car : 1997 Honda Civic LX
Where do I get the replacement bolts when I get this out?
Old Jul 30, 2017 | 12:24 PM
tony_2018's Avatar
Fish Twig
Default Re: Broken Bolts That Hold Sway Bar Bushing Now What? 1997 Honda Civic
Patience, drill stud removal tool, and plenty of beer and swearing
Old Jul 30, 2017 | 06:49 PM
civic402lx's Avatar
Drill
retap
Old Jul 30, 2017 | 07:41 PM
lindylex's Avatar
10 Year Member
tony_2018 and civic402lx, should I use left hand drill bits?
Old Jul 30, 2017 | 09:34 PM
fragmare's Avatar
The best options I can think of all involve MIG welding, oxygen torching, and/or drilling. If you don't have access/clearance for any of that, take the car to somewhere where you do.
If you're going to drill it with the intention of trying to get an extractor in there, I would say definitely use a left handed drill bit. There's a reason extractor sets generally come bundled with left-handed bits. Many times the left handed bit will catch it just right and spin out the broken stud without ever even having the touch the extractor... always a great feeling.
However, if you're going to drill it completely out with the intention of retapping it, I suggest using titanium nitride or (better yet) cobalt drill bit(s), either right or left handed. Individual cobalt bits of varying sizes are only like $5-10 a piece down at the local Ace hardware or whatever. Start with a smaller bit roughly half the size of the final size you need, then bump up to the larger bit once the first bit is through. I wanna say those bolts are probably 10x1.25 off the top of my head, which means you'll want an 11/32" bit for your final cut, then try to carefully thread in a 10x1.25 tap into the hole you just made and hope you can preserve the original threads.
Whatever you do, though, be careful not spin those welded-on nuts on the backside of the frame you're drilling into... if you do that, then... did i mention a MIG welder would come in handy?
Old Jul 30, 2017 | 10:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Why do the work on the roadside ??? A sway bar is NOT a necessary/required device to drive the car. I suggest you get the car to a safer and more user friendly location before you dive into this repair.
Old Jul 30, 2017 | 10:18 PM
fragmare's Avatar
Yea, just remove the swaybar completely, throw it in the trunk and drive to wherever you need. Hell, my 93 DX Coupe didn't even come with a swaybar
Old Jul 31, 2017 | 09:15 AM
94EG8's Avatar
Seagull Management
They're 8x1.25
Old Aug 1, 2017 | 05:16 AM
Delicieuxz's Avatar
5 Year Member
When using bolt freeze to help get a stuck bolt loose, does it weaken the integrity of the bolt and risk the bolt breaking more easily?
Old Aug 1, 2017 | 08:13 PM
fragmare's Avatar
Thanks. OP will need to use a 17/64" bit for the final cut, then.
IntegraGSR1999
Suspension & Brakes
May 12, 2010 12:18 PM
s1ngle
Dec 4, 2007 07:43 PM
Ls_TurboEG
Suspension & Brakes
Feb 10, 2007 07:30 PM
RevedOut
Feb 12, 2002 01:36 PM
