Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Throttle Body Actuator Pinout Description Help
Old Jul 28, 2017 | 05:01 PM
wiki's Avatar
Default Throttle Body Actuator Pinout Description Help
I am hoping someone could help me understand each function of the 2007-2009 throttle body pinout.
I attached a few pictures of the throttle body.
My understanding of the data sheet is this:
pin 1: TPSA - the sensor that measures the voltage going through throttle position sensor A
pint 2: VCC3 - the reference voltage
pin 3: TPSB - the sensor that measures the voltage going through throttle position sensor B
pin 4: SG - the ground pin
pin 5 and 6: ETCSM (+/-) - These are some type of relays that help with the fail safe
I would really like to know how pins 5 and 6 work. I know that they are relays but I just don't know how to connect them.
By understanding the pinout, I hope to make the throttle's valves open and close.
Thanks for the help.
Old Jul 31, 2017 | 11:24 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Throttle Body Actuator Pinout Description Help
What is the point of this?
The PCM controls the Throttle Body plate.
The VCC wire is the reference voltage (5 volts) from the PCM to the two Throttle Position Sensors. The SG is the sensor ground from the PCM to the Sensors.
Both TPS are variable resistors which varies the feedback voltage signal to the PCM based on the angle/position of the Throttle plate. As the Throttle plate opens, one sensor starts at 5 volts and decreases to 0 volts. The other sensor acts inversely, and starts at 0 volts and increases to 4.5 volts. (The Sensors do not measure the voltage as indicated in your post).
Using feedback from the TPS and Sensors from the Accelerator Pedal Position (APP) sensor, the PCM controls the Throttle actuator
motor. One wire is for the motor positive (+) signal and one wire for the motor negative (-) signal. (They are not relays as indicated by your
post).
The actuator consist of the Throttle Position Sensors to provide feedback to the PCM, the PCM operates the motor and gears to move the Throttle plate.
Old Nov 9, 2019 | 11:17 PM
Bill Hodson's Avatar
I have an 06 civic and the voltages on TPSA and TPSB do not behave as he said. They both increase from .5 to 4.5 or so. But I'm having a problem with low rpm misfires. I cant find anywhere with the specs for the voltages. If one is supposed to reduce from 5 to 0 with throttle application then I have a problem.
Old Mar 28, 2020 | 09:20 PM
Anthony Fraley's Avatar
I have the same problem with my 06 if you have found a solution let me know tps a is at 13.3 at idle and tps B is at 31.0% I’m not sure but maybe these numbers should be the same?
Old Oct 18, 2021 | 04:12 PM
Flipnamy's Avatar
post).
on my vehicle I noticed the red and black wire I think is pin number 1 is pulled out. What would that cause my car to do or not do
Old Oct 18, 2021 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
NOT work properly... put the wire/pin back in the connector.
Old Oct 18, 2021 | 09:00 PM
Flipnamy's Avatar
I tried that but still the same problem. It won't start unless I press the gas, it won't rev in park, I have to put it in neutral, then it only revs up to 3500 rpm, then I put it in park and it will rev to 3500 rpm. It also won't go pass 30 mph. I'll try it again I am not sure it made contact
Jimmydwrench
Sep 2, 2018 04:36 PM
stranskydw
Jul 12, 2008 12:40 PM
dmingis
May 28, 2005 09:25 PM
oz`Vtec
Feb 18, 2005 03:51 AM
jisecup
Jul 4, 2003 06:18 PM
