Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Replacing the AC Clutch on a 2001 Civic?
Old Jul 27, 2017 | 02:08 PM
CMW's Avatar
CMW
Icon5 Replacing the AC Clutch on a 2001 Civic?
Hi, I'm new here and looking for some advice regarding my 2001 Honda Civic EX with about 120,000 miles. Recently as I was driving, my AC clutch fell off. My mechanic said I'll have to get a new compressor to fix this, which is going to end up costing me about $500 for parts and labor. I'm really hoping I can simply replace just the clutch instead, and maybe even do it myself. I've read a lot of posts about similar problems, and it seems results will vary depending on the damage to the shaft splines. My question then is this: Based on the provided photos of the shaft splines, do you think there's a decent chance I can simply buy a new clutch and fix this without buying a whole new compressor? Thanks.
The piece that fell off. Looks like the interior splines are completely worn off. Will have to replace.
The shaft, before removing metal filings.
Close-up of the shaft. The splines look in decent shape to me.
Another view of the shaft. The splines need some cleaning, but there are definitely still grooves. Not enough experience to know if these are still good though.
Old Jul 29, 2017 | 11:05 AM
prodjay10's Avatar
Default Re: Replacing the AC Clutch on a 2001 Civic?
I would try it. The splines look good to me. Just need to be cleaned.
Old Jul 31, 2017 | 10:03 AM
CMW's Avatar
CMW
Thanks for taking a look. From what I've read elsewhere, I'll need some shims to get some kind of alignment just right. Would you be able to explain to me what this is about?
Old Jul 31, 2017 | 07:00 PM
prodjay10's Avatar
I've not done it myself but you have to have enough space between the clutch and compressor. That's where the shims come in. They are little spacers. You use some shims and then measure the air gap with a feeler gauge until its within spec.
Old Jul 31, 2017 | 10:45 PM
CMW's Avatar
CMW
I see. Sounds like I'd need special tools then. Think it's doable without them? Trial and error?
Old Jul 31, 2017 | 10:59 PM
prodjay10's Avatar
The feeler gauge is only $5 or so. You can probably do it without. You gotta make sure the gap isn't too big that the clutch won't engage and that isn't too small that it's always engaged.
Old Jul 31, 2017 | 11:04 PM
CMW's Avatar
CMW
Oh I see. You're just talking about something like this?
Amazon Amazon
Old Aug 1, 2017 | 10:16 AM
prodjay10's Avatar
Yes. That's the one
Old Aug 3, 2017 | 06:52 AM
CMW's Avatar
CMW
Great, thanks! By the way, given that the nut came off, any suggestions on how to prevent that from happening again?
Old Aug 3, 2017 | 11:08 AM
prodjay10's Avatar
Torque it to spec and you should be fine. I'm guessing that's the original compressor that's 16 years old now. It lasted this long without anything special.
Now if you still want to make sure it won't come off then add thread locker.
Zebra
Honda Civic (2006 - 2015)
Jan 25, 2018 09:14 PM
M to the H
33
Oct 14, 2015 01:54 PM
spAdam
Jun 4, 2014 05:04 PM
