springs
Old Nov 11, 2002 | 12:30 AM
LSintegra's Avatar
Default springs
would u guys recommend neuspeed springs? cuz i have eibachs on right now and i want it lower but i do not want to cut the coils, thanx.
Old Nov 11, 2002 | 07:13 AM
Integra21's Avatar
Default Re: springs (LSintegra)
hey - my neuspeed sports are coming today - so i will let you know how they are once i drive with them for a little while-
Old Nov 12, 2002 | 01:21 PM
GSRaCeRbOI's Avatar
what kind of Eibachs do you have? the Pro-kit? Sportline? Race?
and what Neuspeed springs are you getting?
my friend has Neuspeed Race springs on his prelude and is pretty happy w/ them... and other friends had neuspeed.. I think it was "sport" series on their Civic hatches and had no complaints..
Old Nov 12, 2002 | 01:41 PM
90teg's Avatar
i have neuspeed race, i love them less body roll then before.
Old Nov 12, 2002 | 02:55 PM
emr88's Avatar
Determine what drop you want, combined with what spring rate you want and find the best spring that matches. Check out this spring rate table:
http://php.indiana.edu/~bchang/Pics/...ate_Table.html
Or go with Ground Control coilover sleeves and you can adjust the drop you want. Make sure to get shocks that will work with the spring rates you choose.
Old Nov 12, 2002 | 04:15 PM
LSintegra's Avatar
Default Re: springs (emr88)
i have the pro kit, did u guys ever hear about goldline springs? i heard they slam ur car, but i dunno how the ride might be like.
Old Nov 12, 2002 | 04:23 PM
IN VTEC's Avatar
I like and recommend linear-rate springs. Progressives have always been too mushy for me.
I recommend sticking with the Eibach Prokits.
Old Nov 12, 2002 | 04:24 PM
LSintegra's Avatar
Default Re: springs (IN VTEC)
do u think a 2.5 in drop would be too much? cuz i want my car to be lower, but not too low. thanx
Old Nov 12, 2002 | 04:38 PM
garados's Avatar
2.5" is too much Going past 1.5" requires a camber kit and still allows a good range of suspension travel. With a 2.5" drop, handling will suck because you won't have enough suspension travel (and room between the tire and the wheel well/fender) and your tires will hate you because of extreme alignment problems. But, if you aren't going to be pushing it through the turns, then go with a 2.5" drop
Old Nov 12, 2002 | 04:41 PM
LSintegra's Avatar
Default Re: springs (garados)
hehe thanx for the tip
Old Nov 12, 2002 | 04:45 PM
garados's Avatar
no prob
Old Nov 12, 2002 | 05:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My car is lowered almost 2" w/ H&R Sport and Koni yellow shocks, no camber kit, no abnormal tire wear. Handling is pretty awesome (that will depend largely on your tires).
Old Nov 13, 2002 | 01:41 PM
GSRaCeRbOI's Avatar
Default Re: springs (PatrickGSR94)
TOE is important...
my car is also lowered approx 2".. I have Eibach sporline springs along w/ Koni Yellows (Sports/adjustables whatever u want to call them)... I also have 16" rims w/ 205/45/16" tires and I don't get abnormal tire wear either... I don't have a camber kit but my last alignment read that wheels had negative camber of ranges from -1.8 deg to -2.1 deg... even w/ no camber kit.. and up to -2.1 deg camber I don't get bad tire wear... make sure your TOE is in check because thats what eats up tires...
I also have Neuspeed strut bars and ST Sway bars..along w/ the Eibach sportline and Koni yellows + 16" SSR's and Dunlop SP9000's.. handling is great IMO... the car hugs the road like crazy and carves turns really well w/ very little body roll...
aalb1
Suspension & Brakes
Feb 7, 2005 05:56 PM
moecivic
Aug 19, 2004 01:13 PM
ChaseIntegra
May 5, 2003 01:15 PM
far
Jan 16, 2002 07:24 PM
Maxime
Jan 8, 2002 07:37 PM
