Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 honda civic cranks but wont start
Old Jul 24, 2017 | 04:15 PM
edson leyva's Avatar
Default 2002 honda civic cranks but wont start
Really appreciate any and all help ... my 2002 honda civic lx cranks but wont start literally happened over night used it the night before then the next morning it wouldnt start .... checked all fuses and relays already ...dont think any of them are bad ....have fue you can hear the fuel pump prime and i verified that its being delivered dont ask how but i know 😂😂.....fresh spark plugs....but what i dont have is spark and i dont know why i doubt its the coil packs because they cant all go bad at the same time
Old Jul 25, 2017 | 03:49 AM
prodjay10's Avatar
Default Re: 2002 honda civic cranks but wont start
Check fuel pressure. Should be around 44psi and should stay Over 20 after 30 min.
You need a spark tester to properly check spark.
Old Aug 10, 2017 | 10:25 PM
Tt1.7's Avatar
i had same problem with 05 civic lx air to fuel was off because of egr behind throttle plate removed battery cables pulled ecm fuse you are not supposed to pump gas to reset run 10 min idling I had to pump gas to start I was told throttle body needed cleaned. Tom
vickyphan
Honda Civic (2006 - 2015)
May 25, 2015 12:07 PM
HooverHonda13
Jan 7, 2014 07:02 AM
Dilyla02
May 13, 2013 12:38 PM
wanna_run
25
Feb 7, 2012 09:11 AM
hamburgler
Aug 21, 2011 10:23 AM
