d17 short block
will a d17a2 shortblock fit with all d17a8 parts?
I'm building a d17 engine but the cylinders are worn out and are out of round. Engine has already max oversize pistons(75.50mm)
Yes it will, you just won't have VTEC if you use the A8 head. All D17 blocks are the same and for the most part all the other parts are interchangeable between all D17 engines. Good luck with your project man!
